Wiring a 5 bedroom house | Page 8 | on ElectriciansForums
Discuss Wiring a 5 bedroom house in the UK Electrical Forum area at ElectriciansForums.net
omoeko
London
Hello Everyone,
I am not sure of the etiquette here on the forum, but I would like to start by extending warm greetings to everyone in the house. This forum is very useful for me and I have learnt a lot from it.
I would like to ask a question, its about the list of materials required to wire a 5 bed house. I have the list below, and would like to know if its correct etc.
3/4 double sockets per bedroom, and everywhere will have spot lights apart from the bedrooms. I also plan to use a double electric oven, which is rated at 4,400W and hence a 6mm cable needs to be used. The distance is about 10m from the board to the kitchen. Below are the oven specification.
Energy efficiency class (2010/30/EC) - cavity 2 : A Energy consumption per cycle forced air convection - cavity 2 (2010/30/EC) : 0.80 Energy efficiency index (2010/30/EC) : 112.9 Energy efficiency index cavity 2 (2010/30/EC) : 94.1 Electrical connection rating (W) : 4400 Current (A) : 20 Voltage (V) : 240 Frequency (Hz) : 50
Description Quantity
Non fire rated spot lights (Lounge) 10
Non fire rated spot lights (hall by door) 4
Non fire rated spot lights (family living area) 12
Non fire rated spot lights (Kitchen) 8
Non fire rated spot lights (Upstairs landing) 6
Non fire rated spot lights (Downstairs toilet) 4
Non fire rated spot lights (Utility room) 2
Bathroom spotlights (Upstairs bath) 6
Bathroom spotlights (Upstairs Ensuite) 4
External spot lights for outside 6
Pendant light 8
Smoke Alarm 2
Heat Sensor 1
Extractor fan 3
12/15 way board with MCB's 1
Kitchen Extractor Chimney 1
Shower shaving socket 2
Isolator for extractor fan 3
1.5mm brown cable 100m
1.5mm blue cable 100m
1.5mm GREEN/YELLOW cable 100m
3 core flexible cable 50m
2.5mm 3 core cable 200m
1.5mm Twin and earth cable 200m
2.5mm blue single core cable
2.5mm brown single core cable
Earth bonding
10mm green earthing
2 gang switch 4
3 gang switch 1
1 gang switch 8
1 gang switch white 2
Outside floor light 2
Fused spur with neon light 3
13amp socket plug 2
Double socket chrome 35
Double socket white 6
Cooker switch chrome 1
6mm cable for cooker 10M
6mm armour cable for garage 12m
Coaxial cable for Tv 50m
Coaxial socket for satellite 2
Electrical trunking 75 x 50mm - 2.4 metres 2.4m
Carbon monixide detector 1
50 pieces of open Grommet 25mm
2 Gang External plug socket 1
Thanks for your opinions.
Only wish you could come and test it once the work is done.
After removing the 1.5mm single cores and 2.5 mm single cores. I think its all good, if anything else is missing, we will buy it. If there was anything concerning, I am sure you would have mentioned it.
I am not an electrician, the closest thing I would do is change a light bulb, other than that, its pass my rank.
that would not have been a fault with materials but more likely a fault with the quality of the installation work.
So that experience should be no reason for you to buy your own materials.
If you really do have an electrician on this job, then order the materials they are asking for, then they will fit them. End of thread.
If you carry on fishing for information we can only assume there is no electrician and you are going to carry out this work yourself. From the initial list you provided I would not say it had been compiled by a person competent to be carrying out this work.
Nope.
Remember I am talking about the past here, this was some 8+ yrs ago.
I dont remember the exact details of the fault as he just said its a faulty cable and it got me thinking, "for a brand new rewiring job within a month", I don't suppose you expect me to be looking over the electricians shoulder to see what he did.
Is this the same house you are planning rewire again?
Yes mate I have something in my workshop something I made when my then boss asked me to do the impossible a wand I think it's called, do't know if any wholesalers stock them.
That was a typo mistake on my path.
I initially wanted to have pendant lights everywhere, however I changed my mind and I have now been told by my electrician that we can remove all the single core brown/blue & earth and buy more twin and earth cables to take care of the spot lights. 250m to be precise. So he does know what he is doing, just feel as though you guys are being harsh on him .
If he knew what he was doing, he wouldn't have been wiring the pendants in singles in the first place. Going on what you've written, neither you or your Electrician (If he exists) have the first clue what your talking about. Your just fishing for information.
I'm done.
Reply to Wiring a 5 bedroom house in the UK Electrical Forum area at ElectriciansForums.net
Echo above, as someone who's probably similarly inexperienced I have set myself up a per point spreadsheet and whack it all in there. This has...
This contactor you suggested unfortunately only has two NO switches rather than 1 NC and 1 NO required for the CR3 current sensing bypass...
