Discuss 2391 sum practical help in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
iv been disconnecting at the MET end and then placing one probe on the pipe and the other on the disconnected cable.
I think the examiners know that a lot of us will not get A level english and so are prepared to cut some slack. That said, it is imperative to get certain terminology right eg it's is an insulation resistance tester not a megger. Call it the wrong thing and I guarantee you will duff a markWow, brilliant!! I'm taking my 2391 in september, there's so much info to work on. The main thing is that i'm a little worried about the written test....I ain't that good at doing essays, also perhaps getting the wording right for C&G standard, but that might just mean I need to read over and over again. Either way I'm looking forward to doing it, if I fail first time, it might give me a chance know what's involved. Thanks Bobby101, great help. :cool4:
Keep on wading through GN3 till you know it inside out and back to front mate, you'll be fine
I'm an out of date dinosaur mate I still uses phases not linesThey've changed it to insulation resistance ohmmeter now :wink5:
no way mate wish they would make there minds up
thanks for the heads up as i have jsut done 2330 302 and it was one of my questions
because of 2391 i learned insulaton resistance ohmeter
now back to IR tester they are getting money for old rope
Reply to 2391 sum practical help in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
