A
amberleaf
O.S.G.. The use of other methods’ of determining Maximum Demand is Not Precludedwhere Specified by the Installation Designer
FirstlyI make no Apologies for the Way am Writing on any Matters . it can be a first day Apprentice or some one Needing aJog of Memory .
Sowe are all in the Same Boat . “ To Learn “
For the Apprentices . The Day we stop learning is the Day we hang Upour Tool-Bag
CookerDesign Current Calculations
Thefirst thing you have to do is get Your Head around the Calculations !!
(From a Design point of View ) 2392-10
DomesticInstallation Oven(s) & Hob(s) are to be Calculated upon their MAXIMUM LOADING
Startwith a simple Calculation ( An Oven has a rating of 2kW ) 2000
(I = P/V ) Formula … I = 2000 ÷ 230V = 8.70A …. Weare Using the Unit Amps
2392-10/ Domestic Installation Oven(s)
Ovenhas 4 Rings ( 2 x 1kW ) & ( 2 x 1.5kW ) & Grill ( 2kW ) & Oven (3kW )
-Controlled via a CookerSwitch with a Socket outlet .
Asa Designer . we’ll have to Apply Diversity ??
Important )- Diversity allowance to be Applied to the FULL LOAD CURRENT for CookingAppliances .
TheO.S.G. is telling us . Purpose of the Final Circuit fed from theConductors )
O.S.G.Table 1B p/97 – column (3) Cooking Appliances → At the Top of the Page Note : Type ofPremises ( 2392-10 → Household Installations ) Domestic Installation(s)
DomesticInstallation(s) Only O.S.G. - 10A + 30% f.l – Full Load ) of connected Cooking Appliances in the Excess of 10A+ 5A if a socket-outlet is incorporated in the Control Unit . ( C.C.U. ) – 45A + 13A Socket Switched with Neon .
Fromyour point of View ( The First 10A ofthe rated current plus 30% of the reminder ( Plus) 5A if the Control Unit incorporates s Socket.
Calculations)- You bank “ Hold OFF“ the first 10 Amps of the Maximum Load Current )
The10A will be used at the End of the Calculations’
-So your Work out the Total Power Rating & then calculate the Full Load Current
Calculations)- Power = ( 2 x 1 ) + ( 2 x 1.5 ) + ( 2+ 3 ) = 10kW
I= 10000 ÷ 230V = 43.48A … round it up to the first four numbers43.47826087 ( 48 ) 43.48A
UsingDiversity allowance stated ↑↑ ( 43.48A sub 10A = 33.48A )
I= 33.48 x 30 ÷ 100 = 10.04A
Youradding the ( 5A ) for Socket outlet . I = 10A + 10.04 + 5A = 25.04A )- Asa Designer this is your Expected Current Demand .
Remember )- Supply Cables Rated to suit DesignCurrent ( Iz ) :)
First Amendment . p/4
Introduction to BS-7671:2008 .
Note 2 )- Particular attention is drawn to Section 701 . This section now allows socket-outlets (Other than SELV & shaver supply units to BS-EN 61558-2-5 ) to be installedin locations containing a bath or shower ( 3m ) horizontally beyond theboundary of zone 1 .
SWA. ?? Example . :hurray:
□ The Wire Armouring is ( Steel ) & therefore is ( Conductive ) The steel is covered by an Exposed Oversheathof Insulation . So not Exposed .
□ The cable is Terminated on mostinstallation(s) with ( Brass-glands ) which are ( Conductive ) These parts aretherefore ( Exposed conductive parts ) these may also be covered with ( PVC. Shrouds )
“ Function(s) “
TheArmouring is to protect the Cable against ( Mechanical damage ) & to allow the cableto be run out of safe Zone .
TheArmouring is connected to Earth to enable the supply to be ( Automatically disconnected) by the ( Circuit Protective Device ) Underthis Fault Condition(s)
Types of ProtectiveConductor . 543.2. :svengo:
543.2.1. A protectiveconductor may consist of ( One ) or ( More ) of the following .
i) A single-core cable .
ii) A conductor in a cable.
iii) A An insulated or bare conductor in a common enclose withinsulated live conductor(s) .
iv) A fixed bare orinsulated conductor .
v) A metal covering . for example . ( THE sheath . screen orarmouring of a cable )
vi) A metal conduit . metallic cable management system or otherenclosure or electrically continuous support system for conductors .
vii) An (Extraneous-conductive-part ) complying with Regulation 543.2.6.
Defining Protective Conductor . p/32
Protective Conductor isdefined in ( PE ) (BS-7671:2008 ) First Amendment . underPart 2 Definitions as .
A conductor used for some measures of protection against electricshock & intended for connecting together any of the following parts .
- Exposed conductive parts.
- Extraneous conductiveparts .
- The main earthing terminal .
- Earth electrode(s) .
- The earthed point of the source . or an artificial neutral .
Earthing Arrangements for Protective Purposes . 543.6. :svengo:
543.6.1. – Where overcurrent protective devices areused for fault protection . the protective conductor shall be incorporated inthe same wiring system as the live conductors or in their immediate proximity .
134.1.4.p/19p/21.
Erection )- Terminating the Cable Ends of S.W.A. cables . :20:
BS-7671:2008. Fundamental requirements set out in Regulation . FirstAmendment / 17[SUP]th[/SUP] Edition
Everyelectrical joint & connection shall be of proper construction as regards Conductance . Insulation. Mechanical strength & Protection .
The most effective way ofTesting for ( Earth Faults) in the wiring or equipment is byMeasuring the Insulation Résistance . as described in Section 6 . 612.3.1.
( Nobreakdown of the Conductor Insulation ) Nails . & Picture hooks . Screws . ???????????? :svengo:
2392-10 .
Floorboards’ Nail driven between the Neutral & Earthconductor(s) creates a ( Neutral to Earth Fault) :hurray:
“ RCD to Trip “
The Fault can be located byInsulation Testing .
Damaged cable must be replaced& either relocated to avoid further damage or protected .
2392-10 :- Requirements to protect cables from Impact& Penetration are given in Regulation 522.6.5. ( v ) p/100 . 522.6.5. the same . ( v ) p/124
Section 712 :
Solar Photovoltaic ( PV ) Power Supply System(s)
712.512 : p/243 Accessibility.
712.513.1. The selection & erection of equipment shall facilitatesafe maintenance & shall notadversely affect provisions made by themanufactures of ( PV ) equipment to enable maintenance or service work to becarried out safely .
Scope .
Section 712 of BS-7671:2008 - ( Applies to the Electrical Installationof ( PV ) power )
Supply systems including system(s) with a.c. modules .
Note )- Section 712 does NOT apply to ( PV )power supply system(s) which are intended for ( Standalone Operation )
New Topics covered . On-Site Guide is Portable Generators .
Two classes of ( TemporaryGenerators ) – (i) Portable Generators .(ii) Mobile Generators .
Generators used for short periods :- One-day & these used for longer timescales .
□ Portable generators with an electrical output rating of up to( 10kVA ) used for small scale work –short term use ( Less than one day )
□ Mobile Generators . used for longer periods & can be in Excess of (( 10kVA ))
• Portable generator used with a Floating Earth .
• Portable generator used without reference to the general mass ofthe Earth .
• Portable generator referenced to the general mass of the Earth .
Permanent use of Generators . Guidance Note 5 - Guidance Note 7 .Section 551 . BS-7671:2008 / 2011 .
Generator(s) are used to ( supply Concession Vehicles ) such as (Burger Vans ) look Section 717 . Mobile & Transportable Units . / GuidanceNote 7 .
Temporarily supply electrical equipment or electricalinstallations with a generator where the mains or usual supply is Unavailable .
Portable generator with Floating Earth :
Small portable generators’ . ranging in ( Output ) from 0.3kVA / 10kVA single phase often have a ( Floating Earth )
Connection of the Socket-outlet of the Unit to the ( Neutral ) of the generator winding.
The ends of the generator winding are brought out to one or more (Three-pin socket-outlet(s) which should conform to BE-EN 60309-2.
[ The Earth socket-tube ofthe socket-outlet(s) are usually connected ( Internally to the Frame of the GeneratorOnly ] ► This arrangement is a form of ( Electrical Separation )
When do NEW INSTALLATIONS have to COMPLY with Amendment No 1 . Requirements
Amendment No 1 July 2011& will come into effect on ( 1 January 2012 ) This means that Installation(s) designedafter ( 1 January 2012 ) will need to comply with the Amendment 1 requirements
An Installation that was designed to the 17[SUP]th[/SUP] Edition “ BEFORE “ 1 January 2012 but gets completed after thisdate should be Certified to the 17[SUP]th[/SUP] Edition
( T ) Testingpurposes :- suitablewarning sign(s) & / or notices shall be provided 2391 / 2392 .
134.1.7. Where necessary forsafety purposes . suitable warning sign(s) & / or notices shall be provided.
134.2. Initial Verification .
During erection & on completion of an installation or anaddition or alteration to an installation . & before it is put into service. appropriate ( Inspection & Testing ) shall be carried out by CompetentPersons to verify that the requirements of this Standard have been met .
Appropriate certification shall be issued in accordance withSection 631 & 632 .
134.2.2. The designer ofthe installation shall make a recommendation for the interval to the firstperiodic inspection & test as detailed in Part 6 .
Note : The requirements of Chapter 34 ( Maintainability ) should be taken into consideration .
135 . Periodic Inspection and Testing .
135.1. It is recommendedthat every electrical installation is subjected to Periodic Inspection andTesting . in accordance with Chapter 62.
Definitions – Part 2 . p/25 .
□ Current-carrying capacityof a conductor .
The maximum current which can be carried by a conductor under specified conditions without its steady-statetemperature exceeding a specified value .
□ Current-using equipment .
Equipment which converts electrical energy into another form ofenergy . such as light . heat or motive power .
Definitions . p/26 . New .to First Amendment :oops:
Discrimination : Ability ofa protective device to operate in preference to another protective device inseries .
Definitions . p/26 . change.
Exposed-conductive-part . :carols:
Conductive part of equipment which can be touched & which isnot normally live . but which can become live under fault conditions .
Conductive part of equipment which can be touched & which is notnormally live . but which can become live when basic insulation fails .
UsefulJunk .
17[SUP]th[/SUP] Edition Wiring Regulations . Requirements forElectrical Installations 2008 . :gettree:
The term ( Phase ) is replaced with the term ( Line )
Line is the Internationallyused term . Do Not confuse ( Line ◄ ) conductor with ( Live ◄ )conductor which can be a ( Neutral ) conductor .
Line Conductor )- p/29 . Definitions
A conductor of an A.C. system for the transmission of electricalenergy other than a ( Neutral ) conductor . A protectiveconductor or a ( PEN ) conductor . Theterm also means the equivalent conductor of a D.C. system unless otherwisespecified in the Regulations .
( PEN Conductor ) p/33 . Definitions
A conductor combining the functions of both protective conductor& Neutral conductor .
Portablegenerator referenced to the general mass of the Earth.
Wherethere are ( Extraneous-conductive-parts ) or ( Exposed-conductive-parts ) fromother electrical systems present .
Generatorreference Earthing by means of an (Earth Electrode ) to the general mass of Earth should beinstalled .
NOTE )- That this does NOTcreate a ( TT Arrangement ) Thesupply will be ( TN-S ) from the generator but the ( Neutral ) or (Star point ) will be referenced to thegeneral mass of Earth .
( Generator reference Earthing - Using Earth Electrode )
Wherean Earth Electrode is supplied it will need to be tested by the Standard Method using a (Proprietary Earth Electrode résistance tester )
NOTE )- That an Earth FaultLoop Impedance Tester cannot be used for this Test as the Earth Electrode is NOT used as a meansof Earthing it used to reference the portable generator to the general mass ofthe Earth . As the Earth Electrode isused for referencing & NOT as a means of Earthing . The résistance should .( Ideally be Less than 200Ω )
If buried . generator reference Earthing&/or Bonding conductors should be sized in accordance with Table 54.1. & suitably protected in accordancewith Regulation 543.3.1. Whererestrictions . such as concreted / paved areas or the portable generator isbeing used some distance above ground level . make it impossible to install anEarth Electrode . ( Simultaneously )accessible metal parts . i.e. accessibleExtraneously-conductive-parts or Exposed-conductive-parts from other electrical systems . may beBonded to the ( MAIN ) Earthing Terminal of the generator .
Whereseparate accessible Extraneous-conductive-parts or Exposed-conductive-parts from other electricalsystems are connected together . protective conductors can be sized inaccordance with Regulation 544.1.1.
Importantto Emphasise that Generators must be Used in “ Accordance with the Manufacturers Instructions “ :iagree:
WhereGenerators are ( Hired from plant-hire companies ) it is ( Responsibilityof the plant-hire company ) toprovide the Hirer with Information regarding the Safe use of their Equipment . Underno circumstances should Hirers attempt to change the Internal electricalconnections of Hired Equipment .
Where( Doubt Exists ) as to the Internal Earthing connectionsof the generator . a ( Continuity Testbetween Neutral & Earth socket-tubesat the socket-outlet can be undertaken ) Very Low reading – Less than ( 0.1Ω ) wouldindicate that it is not a generator with ( Floating Earth)
Responsibilitiesof the Duty Holder :carols:
Minor Electrical Installation Work(s) Certificate .
( Requirements for Electrical Installations BS-7671 [[ IET Wiring Regulations ]]
To be Used only for minor electrical work which does NOT includethe provision of a NEW circuit .
System Earthing Arrangement . TN-C-S - TN-S - TT
Part 2 )- Installation details . Comments on existing installation . Includingadequacy of ( Earthing & Bonding ) arrangements ( T -&-s ) Regulation 131.8. )
131.8. Moved by BS-7671:2008 Amendment No 1 to 132.16 . ◄ p/393
( T -&-s ) 132.16. p/20 .
Additions & Alterations to anInstallation .
No addition or alteration . temporary orpermanent . shall be made to an existing installation . Unless it has beenascertained that the rating & the CONDITION of any EXISTING EQUIPMENT . including that of the distributor . will beadequate for the altered circumstances . furthermore . the EARTHING & BONDING arrangements . if necessary forthe protective measure applied for the SAFETY of the ADDITION or ALTERATION .shall be adequate .
Definitions – Part 2 : p/31 (NEW ) First Amendment :carolers:
Minor Works .
Additions & Alterations to an installation that do not extendto the provision of a new circuit .
Definitions – Part 2 : p/31 / p/28 :christmaswreath:
From a Inspectors point of View.
Reporting : Communicatingthe results of ( Periodic Inspection& Testing ) of an electricalinstallation to person Ordering the Work .
Standard ( PVC )Insulated Cable(s) are designed to operate at Temperature’s up to ( 70°C ) beyond this there is a risk of Damage . :gettree:
p/340 . Table 4D5 - ( 70°C ) Thermoplastic Insulated & Sheathed flatcable with Protective Conductor - ( Copper Conductors ) T&E .
Cableis guided by two main principles’ .
i)Cable should be able to carry the current load ( Imposed ) on it without ( Overheating )
(( Extreme conditions of temperature it willencounter during its Working Life . ))
ii) You should have sufficient sound Earthing - Limit the voltage to which people areExposed . Safe Level . ( Fault Current to trip MCB inshort time . )
OverCurrents can be Classed into two types
Overload )- An overload occurs when a current flows thatis somewhat to High .
□ Overloadsdon’t normally cause immediate damage . ( The likelihoodof Damage gradually as the duration of the Overload Increases )
□Cables will Overheat & Melt . (Exposing bare conductor(s)
□ DomesticInstallations Overloads usually results from using to many Appliances at the same time . 2392-10
ShortCircuit )-
□ isa connection between Line & Neutral . OR Line & Earth .
Youare looking for a ( Low Résistance ) & thecurrent that can flow may be hundreds or thousands of times to High for thesystem .
Thiscurrent is called the ( FaultCurrent or Short Circuit Current )
Short Circuit Current . An overcurrent resulting from a fault ofnegligible impedance between ( Live Conductors L/N ) having a difference in potential under normaloperating conditions . p/34
Fault Current : A currentresulting from a Fault . p/28
InPractice )- DomesticInstallation(s) Overload protection& Short circuit protection are both provided by the same Device . ( MCB ) or ( RCBO )
Additional Protection . may beprovided by an ( RCD )
Residual Current Operated circuit breaker withIntegral Overcurrent Protection ( RCBO ) designed to perform the functions of protection against Overload & Short Circuit.
“ Resi/ dual dual - two - L/N
Circuit Breaker : ( MCB ) Definitions . p/25 - p/21 :17:
A device capable of making . carrying & breaking normal loadcurrents & also making & automatically breaking . under pre-determinedconditions . ( Abnormal Currents )
Such as ( Short Circuit Currents ) . it is usually required to operateinfrequently although some types are suitable for frequent operation .
Just a Reminder : 2392-10 :santa_cheesy:
132.6. Cross-sectional Area of Conductors . ( C.S.A. ) :rant:
:rant:
The Cross-sectional area ofconductors shall be determined for both normal operating conditions & .where appropriate . ( for Fault Conditions according to )
i) The admissible maximum temperature .
ii) The admissible voltage drop . ( Vd )
iii) The electromechanical stresses likely to occur due to ( Short – circuit ) & ( Earth Fault Currents )
iv) Other mechanical stresses to which the ( Conductors ) are likely to be ( Exposed )
v) The maximum ( Impedance ) for correct operation of ( Short Circuit ) & (Earth Fault Protection )
vi) The method of installation .
vii) Harmonics .
viii) Thermal insulation .
The “ Fundamental Principles “
thatare given in Chapter 13 are intended to provide for the safety of persons .livestock & the protection of property against dangers & damage whichmay arise in the reasonable use of electrical installations .
itis recognised that good workmanship by competent persons using proper materialswill reduce any hazards that may arise & that every item of equipment shallcomply with the Appropriate BritishStandard .
Electricaljoints are a potential source of overheating & if NOT securelymade could ultimately cause a fire . for this reason there are severalregulations relating to electrical connections .
Thisis mentioned within Chapter 13 . in regulation 134.1.4. Every electrical joint& connection shall be of proper construction as regards conductance .insulation . mechanical strength & protection .
“Good workmanship by competent persons using the proper materials will reducethe risk of Overheating or Fire . “
Maintenance Free Connections ( 2392-10 )
Junctionboxes are commonly used .
Regulation 526.3.requires that every connection shall be accessible for ( Inspection . Testing & Maintenance )
There are 6 exceptionsto the rule ( vi ) is .
Equipmentcomplying with ( BS-5733) for a ( Maintenance Free ) accessory & ( Marked ) with thesymbol ( MF) & installed in accordance with the Manufactures Instructions .
BS– 5733 . ( Defines ) a Maintenance Free accessory as :-
Anaccessory which does NOT require further ( Inspection . Testing or Maintenance ) afterinstallation in a circuit . & which incorporates ( ScrewlessTerminals ) & cable clamps to secure any associated cables .
TheElectrical Safety Council Technical Manual States that a junction box with Screw Terminals must be ( ACCESSIBLE ) MUSTbe ACCESSIBLE .
Thisis to allow ( Inspection ) of jointswhich could have relaxed or loosened over time . a potential problem withscrewed terminals . SO . unless provision is made for ( Access ) where boarding . carpet or other similar covering is laidover a ( JunctionBox ) it may not be consideredaccessible & maintenance free terminals should be Used .
Appendix15 of the Wiring Regulations which states “ Junction Boxes with Screw Terminals must be Accessible for ( Inspection . Testing & Maintenance ) or Alternatively . use Maintenance Free Terminals / Connection - Regulation 526.3.
“Junction Boxes with Screw Terminals must be Accessible for Inspection …… ETC
Regulation : 526.3. p/106
i) . ii) . iii) . iv) the Same
Regulation : 526.3. p/131 :christmastree1:
v) Joints or connectionsmade in equipment by the manufacturer of the product & not intended to be ( Inspectedor Maintained )
vi) Equipment complyingwith BS-5733 for amaintenance-free-accessory & marked with the symbol ( MF ) & installed in accordance with theManufactures Instructions .
DownlighterJunction box . :svengo:
Whenfitting recessed downlighters the following method would overcome all the issues .
Thesheath of both solid conductors & flexible conductors for the light fittingcan be secured as they enter the Enclosure .
ThisEnables compliance with . Regulation 522.8.5. in particular where it states that thereshall be no ( Undue Mechanical Strain on the Terminations )of the conductor(s)
Regulation 526.8. whichrequires the cores of Sheathed Cables from which the Sheath has been removed tobe Enclosed . can be seen to be complied with .
Cableclamps prevent Strain on Terminations for Compliance with Regulations .
Regulation 522.8.5. p/125 / Regulation 522.8.5. p/101 Thesame
Every cable or conductor shall be supported in such a way that itis not exposed to ( Undue MechanicalStrain ) & so that there is noappreciable mechanical strain on the terminations of the conductors . accountbeing taken of mechanical strain imposed by the supported weight of the cableor conductor itself .
Regulation 526.8. Connectionof multiwire . fine wire & very fine wire conductors .
Regulation 526.8.1. p/107.
In order to avoid inappropriate separation or spreading ofindividual wires of multiwire . fine wire or very fine wire conductors .suitable terminals shall be used or the conductor ends shall be suitablytreated
Regulation 526.9.1. p/131 . Connection of multiwire . fine wire & veryfine wire conductors .
Requirements of 17th Edition Wiring Regulations – BS-7671:2008 .
A further potential problem can be found within the ( Junction Box ) concerning the type of conductors that are typicallyterminated . it is often the case in Domestic Installation(s) that solid twin & CPC cables will be used for the fixed wiring withthe conductor to the light fitting . Etc . or transformer if the lighting is ( ELV )
Being a ( Flexible conductor )
Strands of flexible cable are Secured adequately in the terminal& not been damaged to ensure compliance with regulation 526.2.
Asa Tester . How many time have you seen this . ?? . Q - Junctionbox :bulb2:
Whenthe conductor was removed for (Inspection ) it is clear that some ofthe Strands have been damaged during termination .
MaintenanceFree Terminals ,
Theaccess to electrical connections should be adequate for their ( Safe ) &proper ( Inspection) Testing & Maintenance .
Inthis Respect . connections should be in a locationwhere they can reasonably be reached & where there is adequate workingspace . :svengo:
Whereconnections are made in roof spaces & inter-floor spaces the Enclosures containingthe connections should normally be fixed & provision must be made for theiraccess .
Providing )- These TWO CONSTRANINTS are COMPLIED with .Then the continued use of standard circular junction boxes remain ACCEPTABLE . :iagree:
Plain English .
MaintenanceFree Junction Box )- Suitable for use in INACCESSIBLE LOCATIONS . ( MF ) :svengo:
TraditionalJunction Boxes )- Acceptable forLocations which are ACCESSIBLE .
UsefulJunk .
BS-7671 is a British Standard for the “ Requirements for ElectricalInstallations “ it is important torealise that the regulations apply to the “ Design . Erection &Verification of Electrical Installations
&are NOT intended to be a ( Product Standard ) This is covered at the beginning of thisdocument in Part 1 . Scope :welcome:
Regulation. 113 . Equipment .
113.1. The regulations apply to items of electricalequipment only so far as ( selection& application of the equipment inthe installation are concerned . The regulations Do Not Deal with requirementsfor the construction of assemblies of electrical equipment which are required tocomply with appropriate Standards .
Itis also important to appreciate that BS-7671 does NOTPRECLUDE the use of equipmentthat complies with the appropriate ( Product Standard) regardless of whether the construction of the equipment meets all theRegulations within BS-7671 .
Example.. Etc .
CeilingRose . BS-67 . Etc
Abovehave features which are NOT in accordwith BS-7671 but are ( PERMITTED )by virtue of their compliance to the appropriate ( PRODUCT STANDARD )
Regulation 412.2.2.3. p/62 :20:
Is concerned with ( Ensuring ) thatpersons opening the box do not come into contact with ( Live Parts Unintentionally )
412.2.2.3.
Where a ( Lid or Door ) inan insulating enclosure can be opened without the use of a tool or key . allconductive parts which are accessible if the lid or door is open shall bebehind an insulating barrier ( Providing a degree of protection not less thanIPXXB or IP2X preventing persons from coming unintentionally into contact with thesesconductive parts . This insulatingbarrier shall be ( Removable only by the use of a Tool orKey )
Regulation relating to Junction Boxes is 521.8.3. p/122 . which requires that where ( Two or More ) circuits are terminated in a Single JunctionBox this shall comply with BS-EN 60670-22 :gettree:
Regulation relating to Junction Boxes is 521.8.3. p/98
which requires that where ( Two or More ) circuits are terminated in a Single JunctionBox this shall comply with BS-EN 60670-22 or BS-EN 60947-7.
p/235 . BS-EN 60670-22 . particular requirements forconnecting boxes & enclosures . 521.8.3.
p/236 . BS-EN 60947-7. specification for low-voltage switchgear& control gear . 521.8.3.
Appendix15 ( Informative )
Fig 15A . i) . ii) . iii). the same .
iv) taking account of the total floor area being served . ( As a rule of thumb . a limit of 100m2 has been adopted )
iv) taking account of the total floor area being served . (Historically . a limit of 100m2 has beenadopted ) :20:
Table of Table(s)
Table 41.1. – Maximum disconnectiontimes .
Table 41.2. – Maximum earthfault loop impedance ( Zs ) for fuses . for 0.4s disconnection time with Uo of 230V.
Table 41.3. – Maximum earthfault loop impedance ( Zs ) for circuit breakers with Uo of 230V .
Table 41.4. – Maximum earthfault loop impedance ( Zs ) for fuses . for 5s disconnection time with Uo of 230V.
Table 41.5. – Maximum earthfault loop impedance ( Zs ) for non-delayed RCDs to BS-EN 61008-1 & BS-EN 61009-1 for Uo of 230V – Regulation 411.5.3.
Regulation 411.5.3. Where an RCD is used for earth faultprotection . the following conditions shall be fulfilled : p/50 Wording
Regulation 411.5.3. Where an RCD is used for fault protection .the following conditions shall be fulfilled : p/57 Wording
Aswith the 17[SUP]th[/SUP] Edition . & First Amendment .
411.5.3. Note 2 : Where (Ra ) is not Known . it may be replaced by ( Zs )
Maximum earth fault loop impedance . ( Zs ) for non-delayed RCDsto BS-EN 61008-1& BS-EN 61009-1. for ( Uo of 230V ◄ ) - Regulation 511.5.3.
With the First Amendment : 41.5.
Rated residual operating current ( mA ) 30 : Maximum earth fault loop impedance ( Zs) ( Ohms ) 1667*
Rated residual operating current ( mA ) 100 : Maximum earth fault loop impedance ( Zs) ( Ohms ) 500*
Rated residual operating current ( mA ) 300 : Maximum earth fault loop impedance ( Zs) ( Ohms ) 167
Rated residual operating current ( mA ) 500 : Maximum earth fault loop impedance ( Zs) ( Ohms ) 100
Note 2 : The Résistance ofthe installation earth electrode should be as low as practicable a Value exceeding ( 200 ) Ohms may not be stable . Refer Regulation 542.2.4.
UsefulJunk . ( Electricians Judgement . ) :icon_bs:
Whatshould I do if the Manufactures InstallationInstructions for a product ( Conflict ) with the requirements of BS-7671:2008 . or include inappropriate or unnecessary Technical Requirements’
Any Installation Instructions considered tobe Technically Unsound should be ( Queried ) with the Manufacturer & / or referred to the ElectricalContractors registration body for Information .
Yes. I have had this on Site .
Howmuch power does the Individual Built in-oven Draw . Individual Built in-oven – No hob . Supplied with a ( 13A Plug ) BS- 1363 .
Specs/ Regulations e.g. 3kW / 3000W . ( Maximum you can get from 13A Fuse )
Current - ( Amps )
Power– ( Watts ) / (Voltage )
Current ( Amps ) 3000 ÷ 230V = ( Current ( Amps ) 13.04 Amps) Uo /230V
13Aplug & Socket . ( Note :- 0.04 of an Amp over would be took up in Diversity as stated in BS-7671:2008 17[SUP]th[/SUP] Edition. :gettree:
TheDesign of UK Electrical Circuit means that NOT only is every Individual Appliance Protected by a Fuse . ( Protected from Overloading )
BS- 1363 – p/278 . 13A plugs . Socket-outlets . connectionunits & Adaptors .
BS- 1362 – p/278 . Specification. for general purpose fuse links for domestic & similar purposes ( Primarily for usein plugs )
BS- 1362 – During normal flow of Electricity . The fuse (Permits ) the power to pass Unobstructed . Duringan Unsafe Overload . A small piece of Metal Melts . stopping the flow ofElectricity .
Definitions Part 2 / p/28. p/25 The same.
( Fuse ) A device which .by the melting of one or more of its specially designed & proportioned components. Opens the circuit in which it is inserted by breaking the current when thisexceeds a given value for a sufficient time . The fuse comprises all the partsthat form the complete device .
( Fuse element ) A part of a fuse designed to MELT when the fuseoperates .
Appendix 15 ( Informative )
Ring final circuit arrangements .Regulation 433.1..103 .
2392-10 :
The load Current in any part of the circuit should be unlikelyto exceed for long periods the Current –carrying capacity of the cable ( Regulation 433.1.103 refers )
Thiscan generally be achieved . p/425 .
i) Locating socket-outletsto provide reasonable sharing of the Load around the Ring . :svengo:
iv) Taking account of thetotal floor area being served . ( Historically . a limit of 100m[SUP]2[/SUP] has been adopted ) :svengo:
Does the ( R1 + R2 ) Test confirm the correct polarity of a radialcircuit .
NO )- not on it’s Own Whilst the test can provide an Indication ofpolarity . it needs to be combined with Inspection & further Testing asrequired by part 6 - BS-7671:2008 .
January1[SUP]st[/SUP] 2005 Legislation came into effect which broughtElectrical Work in Dwellings under the BuildingRegulations . ( & made it aControlled Service )
ThisAmendment to the Building Regulations .Known as ( Part P ) imposes “ SAFETY “ REQUIREMENTS
ClassifiesElectrical Installation Work – into two basic Categories , ( Notifiable ) & ( Non-notifiable )
BS-1363: Plug there isn’t ( YET ) a regulation to prevent you from plugging itin .
Eachtype of Fuse has a ( Time – current characteristic) which shows the time required to Meltthe Fuse for any given level of Overload Current .
AFuse is a very basic protection device which is destroyed ( i.e. it Blows )
Just a reminder .
Definitions – p/34 .
Résistance Area - ( R[SUP]a[/SUP] ) . ( for an Earth Electrode Only ) The surface area of ground ( around an Earth Electrode) on which a significant voltage gradient may Exit . :rant:
Justmaking you Aware . -&-s . Common Q/As :santa5:
Stationary Equipment . p/35- p/30 .
Electrical Equipment which is either Fixed or whichhas a Mass Exceeding ( 18kg ) & is Not provided with a carrying handle .
Definitions’ )- p/23
Accessory “ Means . a device . other than current-usingequipment . associated with such equipment or with the wiring of an installation.
Appliances “ Means . an item of current using equipment other thana luminaire or an independent motor .
Supplier– see Distributor
Distributor p23 : Aperson who distributes electricity to consumer using electrical lines &equipment that he/she owns or operates .
Origin of an Installation p31 : Theposition at which Electrical Energy is delivered to an Electrical Installation
Wordingfrom a 2392-10 point of View . ( At the Origin ) ▲ :svengo:
Surge Current P/35 : A transientwave appearing as an Overcurrent caused by a ( Lighting Electromagnetic Impulse )
Surge Protective Device (SPD ) P/35
A device that is intended to limit transient overvoltage’s &divert surge Currents .
p/141.Basics )- 534.2.1. Use of ( SPDs )
where required by Section 443 or otherwise specified . SPD shallbe installed .
i) Near the origin of aninstallation . or
ii) In the main distribution assembly nearest the origin of aninstallation .
534.2.3.6. p/145 Co-ordination of SPDs
SPDs shall be selected & erected such as to ensurecoordination in operation .
536.2. Selectivity between overcurrentprotective devices .
Where Selectivity between overcurrent protective devices isnecessary to prevent danger & where required for proper functioning of theinstallation . the manufacture’s instructions shall be taken into account .
536.3 p/148 . Selectivity betweenRCDs .
Where Selectivity between RCDs . is necessary to prevent danger& where required for proper functioning of the installation . the manufacture’sinstructions shall be taken into account .
Abrasion . damage to wiring systems due to : p/437 :christmastree1:
522.6.1.
Impact ( AG ) p/124 .
Wiring systems shall be selected & erected so as to minimizethe damage arising from mechanical stress . e.g. by impact . abrasion .penetration . tension or compression during installation . use or maintenance .
717.52.2. – (ii) p/248. The wiring systemshall be installed using one or more of the following :
ii) Sheathed flexible cablewith thermoplastic or thermosetting insulated to BS-6004. BS-7211 or BS-7919 .if precautionary measures are taken such that no mechanical damage is likely tooccur due to any sharp-edged parts or abrasion .
721.522.7.1. Vibration ( AH) p/255
As the wiring will be subjected to vibration . all wiring shall beprotected against mechanical damage either by location or by enhanced mechanicalprotection . Wiring passing through metalwork shall be protected by means of suitable bushes or grommets . securelyfixed in position . Precautions shall be taken to avoid mechanical damage due to sharp edges or abrasive parts .
***Cont../ Useful Information for Electricians & Apprentices***
Australia
amberleaf,
Dan,
