***Cont../ Useful Information for Electricians & Apprentices***
A
amberleaf
O.S.G.. The use of other methods’ of determining Maximum Demand is Not Precludedwhere Specified by the Installation Designer
FirstlyI make no Apologies for the Way am Writing on any Matters . it can be a first day Apprentice or some one Needing aJog of Memory .
Sowe are all in the Same Boat . “ To Learn “
For the Apprentices . The Day we stop learning is the Day we hang Upour Tool-Bag
CookerDesign Current Calculations
Thefirst thing you have to do is get Your Head around the Calculations !!
(From a Design point of View ) 2392-10
DomesticInstallation Oven(s) & Hob(s) are to be Calculated upon their MAXIMUM LOADING
Startwith a simple Calculation ( An Oven has a rating of 2kW ) 2000
(I = P/V ) Formula … I = 2000 ÷ 230V = 8.70A …. Weare Using the Unit Amps
2392-10/ Domestic Installation Oven(s)
Ovenhas 4 Rings ( 2 x 1kW ) & ( 2 x 1.5kW ) & Grill ( 2kW ) & Oven (3kW )
-Controlled via a CookerSwitch with a Socket outlet .
Asa Designer . we’ll have to Apply Diversity ??
Important )- Diversity allowance to be Applied to the FULL LOAD CURRENT for CookingAppliances .
TheO.S.G. is telling us . Purpose of the Final Circuit fed from theConductors )
O.S.G.Table 1B p/97 – column (3) Cooking Appliances → At the Top of the Page Note : Type ofPremises ( 2392-10 → Household Installations ) Domestic Installation(s)
DomesticInstallation(s) Only O.S.G. - 10A + 30% f.l – Full Load ) of connected Cooking Appliances in the Excess of 10A+ 5A if a socket-outlet is incorporated in the Control Unit . ( C.C.U. ) – 45A + 13A Socket Switched with Neon .
Fromyour point of View ( The First 10A ofthe rated current plus 30% of the reminder ( Plus) 5A if the Control Unit incorporates s Socket.
Calculations)- You bank “ Hold OFF“ the first 10 Amps of the Maximum Load Current )
The10A will be used at the End of the Calculations’
-So your Work out the Total Power Rating & then calculate the Full Load Current
Calculations)- Power = ( 2 x 1 ) + ( 2 x 1.5 ) + ( 2+ 3 ) = 10kW
I= 10000 ÷ 230V = 43.48A … round it up to the first four numbers43.47826087 ( 48 ) 43.48A
UsingDiversity allowance stated ↑↑ ( 43.48A sub 10A = 33.48A )
I= 33.48 x 30 ÷ 100 = 10.04A
Youradding the ( 5A ) for Socket outlet . I = 10A + 10.04 + 5A = 25.04A )- Asa Designer this is your Expected Current Demand .
Remember )- Supply Cables Rated to suit DesignCurrent ( Iz ) :)
•From a Exam point of View 2392-10 ?
:6:
- AStatutory Document is a Legal Requirement .
- ANon-Statutory Documentis a Recommendation . ◄
UsefulJunk . Appendix 2 – BS-7671 . covers Statutory Regulations .
2391-10)- Answer the Questions in full using correct terminology .
Example. Q / Which is the type of Inspection to be carried out on a New Installation . A / Initial Verification .
2392-10- Certification & Reporting . p/163 ( This is oneyou will get ) Simple – one Q/As
631.3– Where Minor Electrical Installation Work ( DOES -NOT-INCLUDE ◄◄ ) The provision of a ( NEW CIRCUIT) -) The hint is in there !! pleaseread
2391-10- Don’t git mixed up (- 633.1 . Additions & Alterations
ElectricalInstallation Certificate or a – ( Minor Electrical Installation WorkCertificate . shall apply to all the Work of the Additions& Alterations -)
O.S.G.– 9A . 2.5mm[SUP]2[/SUP] / 1.5mm[SUP]2[/SUP]has a résistance of ( 19.51mΩ) per metre .( 58 metres ) of cable will have a résistance of ?
[5.8 x 19.51mΩ = 113.158 ] ÷ 1000 = 0.113]
Root meansquare ( r.m.s. )or effective value of a waveform ( Voltage &Current )
Apprentices.
Test method 1 (- Uses the lineas a return lead . – Otherwise known as the ( R1 + R2 )
Thisis the most common method used for final circuits . Why ?
The Line conductor runs alongside a CPC conductor & this factor is Utilised in theTest .
• Polarityof the circuit is also obtained at the same time .
- YouInitial checking for Continuity .
-So Continuity testing & ( R1 + R2 ) readings .
- (R1 + R2 ) on the Schedule of Test Results .
► Ifwe look at the O.S.G. . 9A . (- Somerows will have the résistance for ( R1 ) &some for just ( R2 ) & also for BOTH .
►2392-10.When using Test Instrument explain the importance of i) Verifying TestInstrument . ii) Regular Calibration . iii) Use of DocumentaryEvidence .
Asa Tester its your reasonably (- You must ensure that your Testing Equipment is Calibrated. Why ? This will indicates that the Instrument is working properly & providingaccurate reading . Downside to this . “ Question“ if you don’t do this . Your Test Results could be Void .
TheBasic Standard Covering the performance &Accuracy of Electrical Test Instruments is ( BS-EN61557 ) which incidentally alsorequires Compliance with the Safety Requirements of ( BS-EN 61010)
MeasuredEarth Fault LoopImpedance ( Zs)
:39:
Asa Tester point of View . it should be compared with the . Ze + ( R1 + R2 ) Total & if it is ( Higher ) then further Investigation should be carriedout .
2392-10. every little bit helps towards 2391-10 .
The measured value of . Ze + ( R1 + R2 ) will →[ NOT include Parallel Paths ] if carried OUT Correctly .
Parallel Paths . you will getenough on your 2391-10 . “ Very Important “
(R1 + R2 ) This value must be Entered for all circuit(s) unless it is notpossible to measure
(R2 ) Where the measurement of ( R1 + R2) is not possible then the ( End to End ) Résistance of the CPCcan be measured using a Long Lead Method –Wander Lead
Apprentices(- RCD – setting on 30mA / be carful & do not mistake the TrippingCurrent for the current rating of the Device ) Just apoint . Yeah
2392-10– Functional Switching .
Table. 53.2. –p/117 .
Theone you will use a lot . BS-EN 60898 . MCB . ( YES ) / Table 41.3 – ( Zs)
Theone you will use a lot . BS-EN 61009-1 RCBO . ( YES ) / Table 41.3 – ( Zs)
(-Résistance in a Conductor . :willy_nilly:
2392-10. you will get this on your Exams Principles’
Ifyou Double the Lengthof a Wire . you will Doublethe Résistance of the Wire .
Ifyou Double the Cross-sectional-Area ofthe Wire you will cutits Résistance in HALF.
Apprentices(- “ Plugs “ Résistance . Why . a Larger EarthPin .
:39:
Becauseof Safety Reasons .
AThick Earth Pin provides a ( Less Résistance )path for the Current to be Earthed.
ForSafety so the ( Leakage Current ) is any ( Will take the Less resistant Path ) to Earth pin. to Earth rather than a person operating the Appliance/ Equipment
Plusyour Ring Final Circuit . is a Continuous Ring - Earthing . sowhen you plug into a Socket . The rest speaks Volumes . Yeah
2392-10– you will hear this in Exams Principles’ . 3/5 day course .Cold Test / Testing .The cable has Not been Energized yet. Yeah . :aureola:
Doyou have ( Parallel Paths ) at this point . No . ( A ↔ B ) Yeah .
Whenwe test the ( r1 to r1 ) we are doing a Cold Test . – Initial Verificationis a NewInstallation .
Socket(s).
Firstly. you are Complying with BS-7671:2008 . ( Dual EarthTerminals )
Example. MK. Socket - Socket have two IndependentEarth Terminals . ( used for “ Clean Earth“ Installation )
Scenario . Keep in Mind you may have 12 Sockets on Ring Final Circuit. ?? Run off Cable ? 50m ↔ ( No Spur at this point )
Mypoint . Megger 1552 time . Set on Ohm’s. ? Zeroed my Test Leadsfirst . ◄
TwoLead(s) on Socket Earth bar = my Readingis 0.23Ω / 0.55Ω - Radical Reading(s) . CopperBar .
Keepthis in mind . This was not on Backbox . yet ( No Parallel Paths ◄ ) A ↔ B
Justa Point to Note Here .
3x 2.5mm[SUP]2 [/SUP] . ( Adding a Spur ?? )
3x 4.0mm[SUP]2 [/SUP] ( Radial ?
6 x 6.0mm[SUP]2 [/SUP] (Stranded . We use Stranded cable for Flexibly .) you will get this on CoP .
Apprentices. Just a Leaning Curve
Apprentices.
Thistakes me back to a point here .
Example. if we use the principles off the Earth pinon a Plug . “ Bigger – Least Résistance . Bigger – Cable - Least Résistance
Amreferring to the Socket . BS-1363 only here . ifwe look at the Earthing Bar – Bigger – if willhelp to clear an Earth Fault much Faster .Yeah
10.0mm[SUP]2[/SUP] / Bigger . CPC .
16.0mm[SUP]2[/SUP] / Bigger . CPC
Amnot using the full Title . ?? Scenario .Domestic Installation – would a 16.0mm[SUP]2[/SUP]help ( Parallel Paths ) :gettree:
Apprentices. So
( Parallel Path ) ????? :gettree:
Parallel Paths (- through the Heating Pipes ( Combi boiler) Before you start saying . you didn’t need to Earththe Boiler . is the Main Water Pipe Earthed . Metal . Yes
Dowe have ( Parallel Paths ) Cold Water feeds the ( Combiboiler )
Sockets. has Contact with the Backboxs . ( Parallel Paths ) . ?? - 20 x backboxes . 20 x Sockets
Seemto be another ( Parallel Path ) involved .
Scenario ??
i)First Fix . I test my ring ( if not cut ) . Cut . by connecting to a connector Block(s) [ r1 – r1 ] – [ n1 – n1 ] [ CPC – CPC ] you reading is True& Low . ( Continuity )
Scenario ??
ii)if I connect Ring to” just “ Socket(s) would my Reading go up . ?? in Ohm’s
Scenario ??
iii)if I connect Ring to Socket(s) & Backboxes . ?? would my Readinggo up . ?? in Ohm’s
Sodo we have . ( Parallel Path ) … Parallel Path(s) takes many forms . Yeah
2392-10.
Ifyou have Measured the ( Zs) then you do not need to ◄►Calculate it. :89:
Scheduleof Test Results . Certification & Reporting . – Earth Loop Impedance . ( 0.74Ω ?? ) Straight onto the Schedule of Test Results
“ DoCheck your Polarity “ ( if we look ◄◄ atSchedule of Test Results / p341 ( Equipment Vulnerable to Testing - Confirmation ofSupply Polarity )
Scheduleof Test Results . ( PFC ) – Ze .at the Origin .
From. GN-3 – Two Fold . 2391-10 .
( Ze ) - i ) . Toverify that there is an Earth Connection . ( Live Test - Line & Earth ) with( Parallel Paths disconnected )
ii ) . To verify that the . ( Ze ). value is Equal to or Less than the valuedetermined by the Designer & used in the Design Calculation .
Remember : to Null your TestingLeads on your Tester . ( kA )
RingFinal Circuit .
• Whatto look for (- there maybe a Dodgy Connection) Readingson Sockets
• Measuredvalue of ( R1 + R2 ) could have a Spur . ( Higher value of ( R1 + R2 )
OldAmber is off on One .
Electricityat Work Regulation(s) 1989 . ( Law )
Part1 . Introduction .
ThePurpose of these Regulation(s)
Circuit Conductor
Conductor
Circuit Conductor “ means AnyConductor in a system which is intended to carry electric current in normal conditions . or to be Energised in Normal Conditions
“ Assessor“ Two-Fold Here.
Electricityat Work Regulation(s) 1989 . Requires proof that an ElectricalSystem is Safe .
Proper Inspection & Testingof a System by ( Competent People ) the rest I have left out . Etc
Includes(- Combined Neutral& Earth conductor(s)
2391-10(- Not Include a “ Conductor “ provided “ Solelyto Perform “ a ProtectiveFunction . to Earth . ◄◄ Hope this helps you along the Way .
Canthe . Line & Neutral& Earth . Become “ Live YES .
2392-10(- Certification & Reporting . ( Electrical Installation Certificate ) are we complying with Electricity at WorkRegulation(s) 1989 . PROOF. :89:
UsefulJunk .
:willy_nilly:
612.2.1.
AContinuity Test shall be made . it is recommended that the Test be carried outwith a supply having a No-load voltage between( 4V & 24V d.c.or a.c. ) & a
ShortCircuit Current of not less than ( 200mA ) ↔ ( 0.2A )
LowRésistance Ohm Meters
Thiscan take the form of a specialised Low-ohm-meter or . Continuity range of anIR/Continuity tester .
Instrumentto BS-EN 61557-4
Measuringrange must cover a span of at least ( 0.2Ω to 2Ω )
Digitalresolution must be ( 0.01Ω )
InsulationResistance Testers . for any 2391-10 . Written Exam. :89:
AnInsulation Résistance Test is the correct term for this ( Form ) of Testing .
Ina Written Exam. ( NOT MEGGER ) . This is Not theName of the Test :89:
• TheElectricity at Work Regulations require that all Electrical Systems . includes TestInstruments – be Maintained to prevent Danger .
SomePoints on Testing . :willy_nilly:
Point to Note : Resistor in Parallel would bring down the Readings .
Point to Note : Could we have a Trapped a Wire / when the Fittings are Screwed back . ?
Point to Note : Do we have a Faulty Socket . ? Spur . ?
2392-10. Volt drop Calculations ( Start of yourDesign Principles’ ) ▼ :oops:
Regulation. wise Appendix 12 voltage drop in Consumer Installation / Table 41.3 Maximum EarthFault Loop Impedance ( Zs ) tell us / ( Uo / 230V ) Single-phase
• Cablesshould . where “ Practicable “ Where a cable is partially or completelycovered by “ Thermal Insulation “ Regulation .523.6.6.
2392-10. ( Design Principles’ you may use One Day) ▼ PS. Not on Consumer Installation(s) – 2391-10 & further down the line .
►►Remember that 2392-10 (- p/48 . Table 41.3.For the Types & Ratingsof Overcurrent Devices listed [ May be Used instead of ►►Calculation] MCBs / RCBOs . Yeah :oops:
Firstly(- Other Methods are NOT precluded ◄ :41:
Appendix14 – p/361
Measurement of Earth Fault LoopImpedance . Consideration of theIncrease of the Résistance of Conductors with increase of Temperature . ETC
Therequirements ( 411.4.5. or 411.5.4 ) as appropriate . are considered to be met when the measured value of Earth Fault LoopImpedance ] Satisfies the following Equation
[Zs (m) ≤ 0.8 x Uo/Ia . Uo/230V .. ? 24A= 9.58 → [ Ze/0.8x Zs/9.58 = 7.66 ]
Asthe Regulation . tells us “ Where
Zs (m) Measured Impedance of the Earth Fault Current Loop up to the most distant point of the relevant circuit fromthe Origin of the Installation . → ( )
Uo . is the Nominal ( A.C. –r.m.s. ) Line Voltage to Earth ( V ) .. Symbols used in Regulations . p/35
Ia . isthe current causing the Automatic Operation ofthe Protective Device within the Time Stated in Table ( 41.1 ) Maximum DisconnectionTimes .
Scenario(- MCB – type B. ( p/249 – BS-EN 6089832A ) .. 32 ÷ 160A = ( Ia / 0.2 ) ↔ ( t )
Or . Within ( 5s ) According to the conditions stated in Regulation( 411.3.2.3. ( A )
i)– Line Conductor to ProtectiveConductor Loop Impedance of the Supply is First Measuredat the Origin of the Installation . ( L / E ) “ Live Test
ii)– The Résistance of the Line Conductor & Protective Conductor of the Distribution/Circuit(s) areMeasured . [ ExternalLoop Impedance ]
iii)– The Résistance of the Line Conductor & Protective Conductor of the FinalCircuit are Measured .
iv)– The values of Résistance measured in Accordance with ( ii ) & (iii ) areIncreased on the basis of the Increaseof conductor Temperature . Taking into considerationthe ( Design Current – Ib )
v)– The values of Résistance increased in Accordance with ( iv) are Finally Addedto the value measured at ( i ) to obtain a realistic value of ( Zs ) Under Earth FaultConditions .
Remember that 2392-10 (- Formula . Calculating – Earth Loop Impedance. - Zs = Ze + ( R1 + R2 ) – for Apprentices Internal/ External - ( R1 + R2) Simple . Yeah
Foodfor Through – Regulation 433.1.5. ( Wording ) Can generally be Achieved by it / Doesnot say it is Achieved BY ?? :34:
Scenario(- 2392-10 .
( Ib ) in each Leg of cable is not to be Exceed ( 20A ) Current will not bethe Same All Around ( Ring FinalCircuit )
Assumedto be ( 20A ) at far End ( Additional / 12A ) Evenly Distributed. ◄◄◄
(32A + 20 = 52A ÷ 2 = 26A . ( Lvd) 4 x11.5 x 1000 ÷ 26 ÷ 18 = 98.4m )
( In ) 32A + 20A = 52A ÷ 2 = 26A
(-Other Methods are NOT precluded ◄ :41:
( Lvd) 2 x 11.5x 1000 ÷ 20A ÷ 18 = 63.8m .. Point toNote . ( 2 )
( Lvd) 4 x 11.5x 1000 ÷ 20A ÷ 18 = 127.7m .. Point toNote . ( 4 )
amberleaf,
Dan,
