T
trev
So you're a partly fledged lawyer then? A Electrical Trainee lawyer if you will?I'm not a full-fledged lawyer by any manner of means so don't take the above as professional legal advice.
mmmm ...... so to the extreme you don't do any testing/inspection because you use limit/op reasons not to ( a quick drive by). You then give a "satisfactory" for continued use based on your caveates and the client (not technically minded as to what results do/do not mean) assumes all is good and carrys on as per normal safe in the knowledge he has this piece of paper which he is led to believe discharges his duties under the EAWR's.
Just ragging you Nick, sometimes the opportunities present themselves.
I always thought a diploma was a bit down from a degree though
Either way, you'd still have to do the LSF/Bar finals to be able to claim full qualification as a solicitor/barrister
