A
amberleaf
2392-10 .
The most important, & overlooked, aspect of safety in electrical-testing is that of a , skill of theoperator-undertaking the testing .
Residual-current-device ,test-instrument
Regulation(s) 612.8.1. & 612.10 require the use of an RCD-test-instrument toBS-EN-61557-6 , to test the operation RCDs used for fault-protection &additional-protection . respectively .
Sources of information
Initial-verification isintended to confirm that the installation complies with the designer’srequirements and has been constructed, inspected and tested in accordance with BS-7671. In your case here. 2392-10. Installer / Designer .
Functional 612.13. : & 612.13.1. 612.13.2.
Activities to becarried out: Etc.
All RCDs to be checked both by , Testinstrument and by Test button
All Manually-operated-circuit-breakers tobe operated to verify they open and close correctly.
Operation of circuit-breakers . ( Don’t overlookCircuit-breaker(s) because of RCDs / RCBOs )
All circuit-breakersshould be inspected for visible signs of damage or damage caused by Overheating.
Each circuit-breaker should be manually operated to ensure that the device opens and closescorrectly
