Discuss Spur with two sfcu on it in the UK Electrical Forum area at ElectriciansForums.net
No need to run it 2.5...
1.5 will do
See OSG 1st one isn`t fine.
In wich case can you give us an explanation as to why not, I'll be very interested in your reasoning
Yea but it's fused with the 3a sfu??
Maybe you should look at the pics again. Neither picture is showing a spur that isn't fused
Taffy there is nothing wrong with the first one, have a look at Appendix 15 in the regs book page 425.
The light switch and boiler are both SFCU with 3amp fuse fitted according to the picture.
The spur, ie the cable, is not fused. If it was, the fcu would have to be part of the ring. Then again ,we can all nit-pick.
Reply to Spur with two sfcu on it in the UK Electrical Forum area at ElectriciansForums.net
