I cant see how to collectively take main tails and earth all in one though, because the main bonding (water/gas) must have to go through the same holes as the tails
The regulation says protective conductor, not circuit protective conductor
We are discussing circuit protective conductors.
This is where this started, and it has not changed, as I have said from the start, where it is REQUIRED.
Now you are trying to change the topic to something else to try to make it look like you were right when you were wrong.
Look the devil is in the detail, the word is REQUIRED, it it's not REQUIRED, then it has to be collectively surrounded by ferrous material.
IF it is required, then it is almost definitely not a cpc, thus not part of the original discussion, end of.
No because they are not part of the supply circuit supplying the power to the board.
They are BONDING conductors not cpc's.
The discussion started with an earthing conductor, which is a protective conductor which performs the functions of both cpc and main bond. I was wrong about the question, now despite your unhelpful attitude I have learned that I was wrong and think I can see why the regulation is the way it is.
Read and understand the relevant reg.
IF the 3 conductors are part of the same circuit then they must be collectively surrounded by ferrous material, unless they come under the deviation in the 3rd paragraph.
Someone has posted a pic of the book earlier, look at it, read it and understand it, then all will become clear.
Where did that come from?
Now you have me confused!
No Paul, this is your post No 24
They don't allow it to enter through a different point, never have.
You slipped the 'required' red herring in later, I assume when you actually read 521.5.1
Why do you keep repeating the word 'required' it's irrelevant. You either can or you can't bring the protective conductor through a separate opening.
Advice on regulation 521.5.1
spadge47,
HappyHippyDad,
