Plant Pot Brigade!
A
andrew692003
Does anyone want to join? :)
As I've stated before I have never used these between floors or in any new builds so don't get out the sniper rifles straight away! ;)
The only time I have used clay pots has been in lofts where access isn't a problem and usually in older dwelling houses. Now, the last time I did this was a good couple of years ago not that that matters as I can't see a problem with it.
When fitting the pots I always make sure that the insulation is clear of the hole and all dust etc has been cleaned away then I fit the pot with the transformer outside lying on top of the insulation. I always push the insulation up against the pot which makes it very steady.
At the end of the day all you are trying to achieve is to stop debris falling on the lamp and letting the heat dissipitate to possibly stop causing fire so, does it matter whether you use a firehood, plasterboard box or a bloody clay plant pot?
Firehoods can be expensive and a PIA to fit, Plasterboard boxes take time to build and even the cheapest Firerated fittings can still up the cost considerabaly.
Cheers
Your making the assumption that I advocate the use of plant pots.
Nor the plasterboard one, that would likely smash as well; you are also making the assumption that Mr careless hasn't kicked half of the fire hoods around his loft space whilst dragging the telly & riding his bike around up there.:D
If it were a plasterboard one it would have to be held together by something strong like timber and if adopting that method I would suggest that it is designed to withstand something falling on it.
if you install a fire rated fitting fails it's down to the manufacturer not you'
if you install a plant pot and a standard gimble fitting ( as an example ) and the spread of fire or smoke can be attributed to your fitting and plant pot whci don't comply to part p you could be held responsible for negligence i.e. You failed to comply with building reg's don't forget we live in a litigation mad society, why do think there are so many health and safety rules - not for fun it's so everybody covers their arse .
With regards to your question how? Examine a fire rated fitting and the a gimble fitting you'll see how
well said:d
Doh really? My point entirely
No-on mentioned 'gimble' fittings apart from you, all other posts were talking about using fire rated downlighters
I think this post has run its course.
O.K. Shall we debate toridorial transformers vs. magnetic:D
What do you think would happen if this fitting got hit by the Bike or TV in the loft? ;)
Dunno about the fitting but the bike would get a puncture and the tv would want retuning
Sorry Boy's I couldn't resist :D:D:D
Bikes and TV's aren't common in lofts but if one did happen to fall on this downlighter then it would probably push it out of its hole.
Not such a big deal really!
Of course but that depends if something is blocking it.
but if a bike, TV etc fell on a clay pot. who knows whats next especially if smashed during a fire or before debris would then push and then rapid fire spread is more likely. Those things would not happen if adopting a well built Plasterboard case with ply on top as protection or a metal case.
I have seen such items in lofts on many occasions and with the upturn in MTB its now more likely:D
Just had a call from a customer who wants 30 plus downlights fitted and asked if I could use clay pots to keep the cost down as they need it done quick before they have insulation top up.
I said yeah the Pee Growers Society sell em cheap and they have a big P on the side. Paint the P green and it'll be Ok!
andrew692003,
Spudnik,
